MF 1155 clutch
Bill from Scotl
01-05-2008 15:51:54
Hi Guys
I am about to change over the wrecked engine in my 1155 for a good one from a combine. When changing over the clutch and flywheel should I be cautious when dismantling the clutch? Can I get hurt? Are there safety precautions I need to take or can I simple dismantle and change the parts over?
Thanks
Bill
Holm
01-05-2008 16:59:38
 Re: MF 1155 clutch in reply to Bill from Scotland, 01-05-2008 15:51:54
You can remove the pressure plate without any problems. The pressure will be off of the pressure plate before the bolts are all the way out. I take every other one completely out and then do the remaining ones a couple of turns at a time in a circle so there is not alot of pressure on the last bolts loosened.
