log spltter
andys
01-16-2008 15:58:54
Would fitting an isolator valve to my massey 135 give me a little more power for a log splitter?
DavidP, South Wales
01-17-2008 11:50:02
 Re: log spltter in reply to andys, 01-16-2008 15:58:54
No, you won't get any more power but you will get all that is available.
DavidP, South Wales
andys
01-18-2008 06:59:55
 Re: log spltter in reply to DavidP, South Wales, 01-17-2008 11:50:02
Thanks for the reply David.To be more specific if you can help,is there a certain amount of power loss because the lift arms have to go up which would not be the case if the isolator valve was used?
DavidP, South Wales
01-18-2008 10:44:04
 Re: log spltter in reply to andys, 01-18-2008 06:59:55
Hello Andy,
Yes, you are right to a point. It does take some hydraulic power to hold the arms up. The drain is minimal unless you have an internal leak from the cylinder for example. If it was my tractor I would certainly go for an isolating valve as it gives you more control over the system.
DavidP, South Wales
