Return line on isolator valve????????
Arch in KY
01-20-2008 08:16:02
To run a two way cylinder with isolator value do you have to have a return line to the tractor other than at the valve.Thanks Arch
Arch in ky
01-21-2008 13:28:11
 Re: Return line on isolator valve???????? in reply to Arch in KY, 01-20-2008 08:16:02
Thanks David P the one I order is a 3 way and it one is the three point and 1 is singlr and one is for a two way Thanks Arch
DavidP, South Wales
01-20-2008 12:06:40
HiArch,
First of all it depends on the type of isolator valve that you have. If it is a simple one you will need to have a seperate double acting control valve. You will need a supply pipe from the iso valve to the da valve and a return line to a point on the transmission such as the filler plug next to the main gear lever.
If your iso valve and da valve are integral you will only require the two pipes to the da ram. Return oil will be sent back to the transmission through the valve.
DavidP, South Wales
