Massey 1155 input shaft
Bill from Scotl
01-20-2008 12:50:51
Hi Guys
Just split my 1155 this afteroon to replace engine. When seperating the engine from the gearbox the input shaft came out with the engine(it was stuck to the clutch). Once the engine was safely removed I managed to get the input shaft out of the clutch splines and just pushed it straight back into the gearbox, it went in just fine. My question is has anything dropped down into the bottom of the gearbox by this shaft coming free? Thanks
Bill
Wayne in Iowa
01-20-2008 17:35:04
 Re: Massey 1155 input shaft in reply to Bill from Scotland, 01-20-2008 12:50:51
From your discription, is sounds like the PTO shaft stuck in the engine hub. Putting it back in would not create a problem as long as you twisted it enough to reenter the splines at the rear. NOW, did you look at the splines on both ends of this shaft. if they were worn half or more, you will have a problem some time in the future, like no hydraulics.The transmssion clutch shaft was probably the hollow shaft you stuck the PTO shaft back into the tranny.
