Information on MF20 Industrial
dolphstanley
01-23-2008 10:37:44
I am looking for any and all info about a MF 20 Industral with a MF 32 or 34 loader i cant remember which one. Where can i get specs, manuals or any other useful info you need when you own one thanks
dolphstanley
01-26-2008 15:01:50
 Re: Information on MF20 Industrial in reply to Steven, Avilla MO, 01-23-2008 10:37:44
It apperers to be a sims cab and it has the shuttle shift does anyone know where a good place to get parts for this tractor?
dolphstanley
01-25-2008 08:45:03
 Re: Information on MF20 Industrial in reply to hayray, 01-23-2008 10:37:44
I found out that it is a 1970 model and it has the mf 32 loader on it with a day cab all looks to be factory. I keep hearing about the 135 models, how much are they and my mf20 industrial alike?
135 Fan
01-25-2008 23:18:27
 Re: Information on MF20 Industrial in reply to dolphstanley, 01-25-2008 08:45:03
The MF 20 is an update from the 2135 which is an industrial version of the 135. The MF 20 could have a shuttle transmission instead of the standard transmission like on the 135. The 20 will have a heavier non adjustable front axle and power assist steering. It will also have differential lock and hand and foot throttle. A big advantage with the loader is the front mounted pump which is way faster and doesn't limit the use of the 3 pt. when using the loader. Is the cab on yours a Sims cab? Dave
dolphstanley
01-24-2008 07:35:06
 Re: Information on MF20 Industrial in reply to old, 01-23-2008 10:37:44
thanks for the info the people i bought it from were a little off on the year
chuck bergstrom
01-23-2008 14:13:44
 Re: Information on MF20 Industrial in reply to dolphstanley, 01-23-2008 10:37:44
Hi, You have a 1970 unit by that s/n. The MF20 usually did have a 32 loader. These were built
1970-1972. Chuck
135 Fan
01-24-2008 10:00:38
 Re: Information on MF20 Industrial in reply to chuck bergstrom, 01-23-2008 14:13:44
According to Big Deans site MF 20's were made up to 1976 and were replaced by the MF 20C. I have a cab off of an MF 20 on my 135. The MF 34 loader wasn't offered on the 20 but was on the MF 40 and larger MF 30. Dave
dolphstanley
01-23-2008 10:40:39
 Re: Information on MF20 Industrial in reply to Robert Myatt, 01-23-2008 10:37:44
It has a serial # 9A92998 can anyone tell me how to decifer it
dolphstanley
01-23-2008 10:39:24
 Re: Information on MF20 Industrial in reply to Bryan H, 01-23-2008 10:37:44
It has a 3 cyl deisel engine in it shuttle shift forward and reverse 3spd tranny hi/lo range i do know that much.
