Removing 1155 oil pan/sump
Bill from Scotl
01-26-2008 09:59:57
Hi Guys
Have just taken out all bolts from the oil pan to the engine block and have this free by about 1/2 inch but something seem to be preventing it coming off entirely. I think it could be something at the oil cooler side. Any ideas appreciated as I dont want to break anything. Also does anyone know the torque setting for the flywheel bolts.
Thanks for now.
Bill
Holm
01-27-2008 17:04:16
 Re: Removing 1155 oil pan/sump in reply to Bill from Scotland, 01-26-2008 09:59:57
Bill, I think you will have to change the crankshaft.I don't think the woodruff key will hold to pull the hyd. pump. Holm
COBROLLER
01-26-2008 10:04:45
you have to remove the oil cooler from the left side and pull the tubes going to it out
Bill from Scotland
01-27-2008 12:20:22
 Re: Removing 1155 oil pan/sump in reply to COBROLLER, 01-26-2008 10:04:45
Thanks this worked a treat, sump came off very easy. Next problem is the drive pulley for the vee belts at the front which are different as is the drive arrangment on the end of the crank. The tractor engine is splined while the combine has a wood drift key. Looks as if I am going to have get some fancy machining done.
Thanks again Bill
