270 MF 3PT LIFT
BOWTIEIH
01-27-2008 10:47:56
LIFT WILL WORK AT LOW RPM BUT JUST AS SOON AS RPMS GO UP IT STOPS. YOU CAN WITH RPMS UP, PULL THE AUX LIFT LEVER AND 3 PT ARMS WILL MOVE JUST A LITTLE. JUST AS SOON AS YOU IDEAL THE ENGINE THE LIFT WILL RAISE. IT SEEMS LIKE IT COULD BE STAVING FOR FLUID. I JUST PUT THIS UNIT BACK TOGETHER AFTER PUTTING A BRAKE ON THE PTO HUB. EVERY THING WORKS FINE AS LONG AS THE ENGINE IS IDEALING
BOWTIEIH
01-28-2008 10:15:49
 Re: 270 MF 3PT LIFT in reply to BOWTIEIH, 01-27-2008 10:47:56
I cleaned the filter in the bottom of tractor.
awoods
01-27-2008 16:01:31
Witch filter did you clean? Both one in bottom or the on one in canaster? I have about the same issue with my 275 plus the pto issue I posted.
BOWTIEIH
01-27-2008 15:53:15
Thanks to mwhisnan, I have the tractor going. It seams the hyd filter was the issue. Toke it out cleaned it in gas. working fine now.
DavidP, South Wales
01-27-2008 14:11:20
Hi,
It certainly suggests lack of oil. Drain the level to the bottom bolt on the side cover and remove the RH cover. Observe the operation of the pump lever. Should move rearwards with levers raised until arms reach selected height. It will then move forward to the vertical neutral position.
If you do not have this movement the problem will be in the lift cover. If you do it suggests lack of oil or a pump problem.
DavidP, South Wales
