mf m20 industrial deisel fuel system bleeding
dolphstanley
01-30-2008 13:57:58
How do you get all the air out of the system when you do a filter change?
dolphstanley
02-01-2008 13:01:59
 Re: mf m20 industrial deisel fuel system bleeding in reply to Marlowe, 01-30-2008 13:57:58
I finally figured it out I keep going back to the books and finally found the 2 bleeder screws on the injector pump and figured out the injector lines that come off of the injector pump had to be cracked and the engine turned over to did all that and she runs the best she ever has the book keep refering to the manual pump on the other side of the engine it should have a lever to pump and that would bleed it but my tractor has the manual pump but no lever to pump i dont know it it fell off or never had one so i just cracked the lines and bleeders on inj pump and cranked the engine and it worked thanks
135 Fan
01-31-2008 11:09:30
 Re: mf m20 industrial deisel fuel system bleeding in reply to dolphstanley, 01-30-2008 13:57:58
Look in the archives on here or go to Big Deans site. Same as 135 procedure. Dave
