the new 596 massey tractors
acdave
02-01-2008 19:19:33
does anyone know anything about these tractors i am thinking about buying one and was just wondering about them any thoughts or ideas thanks Dave
acdave
02-02-2008 21:31:25
 Re: the new 596 massey tractors in reply to acdave, 02-01-2008 19:19:33
thanks josh yes i dont think i would do a lot of plowing with the tractor mostly lighter field work
pulling a 6 row planter without fert. spraying moving wagons and hay work but ocasionally it might have to pull a 14 foot field cultivator or haul grain to the eleviator that would be the heaviest work it would do
JoshuaGA
02-02-2008 19:41:05
Very mechanical, should be easy to work on. Fairly comfortable cab, but a bit short if you are tall. Good proven transmission and hydraulics. Dont think it would make a good loader tractor, shuttle transmission much better. Great haying, spraying, and light tillage tractor, but wont last in heavy tillage. If this is going to be a main tractor, you will thank yourself for buying a large frame tractor, unless you already have a bigger tractor. I wouldn't worry about the tractor, they shoud be reliable unit if not overworked and taken care of. No danger points that I've heard of. HTH
JoshuaGA
