Marvel/Schebler
Venturi Seating?
BlueLight
12-15-2000 10:08:51
Does the brass venturi in the carburetor have
to fit tight on the top and bottom flange when
each half of the carb is screwed on tight?.
Mine is a bit loose. I can bend each flange
upward and downward respectively to give a better
seal but because of the scarcity of this part, am afraid to do so. My guess is that it's not that
big a deal.
I'm running a rich fuel mixture and that's
one area I want to fix if need be before I start investigating the problem.
Thanks.
mhgofast
12-15-2000 20:37:30
 Re: Marvel/Schebler - Venturi Seating? in reply to BlueLight, 12-15-2000 10:08:51
Yes, it does have to fit tight to make the carb run right. Bend away. If you need another one call Motec Engineering @ 765-963-6628. They can get Marvel Schebler part at a fair price. They won't screw you like Dennys will.
Alberta Mike
12-15-2000 10:54:09
I would expect that it should be pretty close, however you might have a problem getting it 100% tight, one reason alone being that a different gasket thickness could make it tighter (if the gasket was thin) or looser (if the gasket was thicker). When you say 'venturi', I am assuming that you are referring to the trumpet or horn-shaped piece in the throat of the carb, is that correct? I wouldn't think they are meant to be bent because in some carbs (even MS ones), that part is cast pot metal (not pressed brass). I guess a guy could 'gasket' the venturi where it sits in the carb casting to get a little closer tolerance to the other half of the carb.
BlueLight
12-16-2000 06:27:07
 Re: Re: Marvel/Schebler - Venturi Seating? in reply to Alberta Mike, 12-15-2000 10:54:09
That's right Mike. The metal is very thin
at the lips. Not sure if it fits tight when the
2 halves are together squeezing the gasket.
I thought of forming a piece of copper wire
in a circle to just fit under the lip. Then
getting a piece of pipe and gently push down
to bend the lip.
Don't like to muck around with it though.
Maybe I'll try a thinner gasket.
Thanks guys for the info!.
