Massey 97
Chief 83
02-17-2008 06:40:39
I have recently purchased and yet to take delivery on a Massey 97. I'll get manuals ordered very soon. In the mean time could someone scan the starting/stopping instructions for me? It would be a bit embarrasing to have it show up and not be able to get it off the truck.
Thanks,
kirk in ks,
02-17-2008 08:14:17
 Re: Massey 97 in reply to Chief 83, 02-17-2008 06:40:39
Well,, all you have to do is make sure the battery is up as its a large diesel,
and then make sure theres fuel in it and the filters arnt clogged or worn out,
Go to the primer if it has one, and unscrew it and pump it a couple times to get fluid in the injectors, then close it, and go to the switch
on the dash, turn it on check for light on the amp guage, give it a little throttle,make sure its in neutral, and either turn the key, or push the starter button,
and if it lights it shoud blow a little junk out if its been sitting and then just let it warm up for a while and then put in it reverse and slowly back it off the trailer,
