254-4 injection pump
254-4 in pa
02-18-2008 17:49:31
hi out there i need helppp i have a 254-4 with the 3cyl diesel it will run a few minutes and die a little shot of either itll start and die again i think its the injection pump as i replaced the other pump last spring when i had the pto fixed there arent any massey dealers left here by me as the city advances i would like to know where to get pump@injectors as this a good tractor for us thanks for any help
254-4 in pa
02-19-2008 15:21:20
 Re: 254-4 injection pump in reply to 254-4 in pa, 02-18-2008 17:49:31
yes fuel filter is ok this problem actually started late summer early fall as sometimes it would cut out above half to 3/4 throttle we just throttled back somethings worn just cant ask any more out of her id like to find a good used pump as funds are low this time of year thanks for repling
Don Snyder
02-18-2008 19:11:36
Have you checked fuel filter? Becareful with the either to much can cause damage to the engine
