MF50
Brian Shelby
08-14-1998 14:19:49
I found a MF50 gasoline powered that the owner is asking $3500 for. What is the tractor worth? It looks in good shape. Will it pull a small square bailer? The owner claims it is a 1965 model and is 63 HP. Is this correct? Any information would be appreciated.
Gerald
08-14-1998 18:32:27
 Re: MF50 in reply to Brian Shelby, 08-14-1998 14:19:49
: I found a MF50 gasoline powered that the owner is asking $3500 for. What is the tractor worth? It looks in good shape. Will it pull a small square bailer? The owner claims it is a 1965 model and is 63 HP. Is this correct? Any information would be appreciated.
'65 sounds late. Since it uses the same gas engine as my 35 hp MF135, a Continental Z-145 (as I've learned in this discussion group) I'd asy its 35 hp.
I've baled up to 500 square bales a day with my MF-135 and MF-12 square baler. HP isn't a problem for the baler with a flywheel, its mostly a problem in moving a heavy baler in damp ground while dragging a rack with 100+ bales behind the baler.
Dann Parker
08-26-1998 20:34:42
 Re: Re: MF50 in reply to Gerald, 08-14-1998 18:32:27
: : I found a MF50 gasoline powered that the owner is asking $3500 for. What is the tractor worth? It looks in good shape. Will it pull a small square bailer? The owner claims it is a 1965 model and is 63 HP. Is this correct? Any information would be appreciated.
: '65 sounds late. Since it uses the same gas engine as my 35 hp MF135, a Continental Z-145 (as I've learned in this discussion group) I'd asy its 35 hp.
: I've baled up to 500 square bales a day with my MF-135 and MF-12 square baler. HP isn't a problem for the baler with a flywheel, its mostly a problem in moving a heavy baler in damp ground while dragging a rack with 100+ bales behind the baler.
My 1959 MF50 has the Z-134 Continental, and it is rated at 33 hp.
Steve Standiford
08-28-1998 18:39:20
 Re: Re: Re: MF50 in reply to Dann Parker, 08-26-1998 20:34:42
Here's the info on the MH-50 (same tractor as the MF-50), with a Continental 134, from the Nebraska tests. Drawbar horsepower only 24. The seller is completely in the dark on the horsepower of this machine. His dates may be pushing it a bit, since the MF-50 was around 1957-64 (and maybe early '65). But, it will have plenty of power to pull a small square baler. I haven't found much on the small farm that my 1956 MH-50 can't do.
Model:Massey-Harris 50 (Massey-Harris-Ferguson Inc., Detroit, Mich.)
Date Tested: September 25 to October 4, 1956
tractor equipment:
Continental 4 cylinder engine, 2000 rpm, 3 5/16 inch bore X 3 7/8 inch stroke, 134 CID 11-28 rear tires 6.00-16 front tires tractor weight: 3432 lbs
Test H Data:
gear: 1, high range speed: 5.12 mph load: 1766 lbs slippage: 4.33% rated load: 24.09 drawbar horsepower fuel economy: 9.74 horsepower hours per gallon
920 lbs of ballast was added to each rear wheel for tests F, G and H. Test G resulted in a low-gear maximum pull of 3525 lbs at
1.14 mph with a slippage of 15.23%. Fuel economy at Test C maximum load of 31.36 belt horsepower was 11.47 horsepower
hours per gallon. Test D rated load of 29.4 belt horsepower yielded 10.97 hp hours/gallon.
Steve Standiford
08-28-1998 18:45:23
 Re: Re: Re: Re: MF50 in reply to Steve Standiford, 08-28-1998 18:39:20
OOPS. Forgot to give credit for the Nebraska test data to the Unofficial Massey-Harris Home Page
http://m-.cs.uoguelph.ca/
