massey 35 fuel problem
cam2
02-23-2008 06:32:20
could some one plese give me a quick run down on how to bleed the fuel system on my massy 35 it a four cyl diesel covington motor. cant seem to get it going
gerry eggart
02-25-2008 09:14:28
 Re: massey 35 fuel problem in reply to cam2, 02-23-2008 06:32:20
Though it's for a 3 Cyl Perkins, some what similar.
Check out www.freetractormanuals.net & click the start button Lower left corner, then our shorts. You'll get a pdf of how to do it w/pics.
Thanks,
BTW. Get a manual from this site... worth it's weight in $$$
Chuck (CA)
02-23-2008 19:42:48
Hi am2,
I"ve done my 4 cyl diesel Standard motor on my TO35 several times due to stupidity. (running out of fuel). (Is it the same engine?)
Starting at the tank and moving forward; Open the top valve on the back filter and pump the lever on the fuel pump until fuel starts coming out. Tighten valve. Do the same with the forward filter. Continue on to the injector pump and repeat.
Go to the injectors and crack them open one at a time and do the same.
Yes, your hand will get tired by pumping the lever.
That should do it.
Let us know how it comes out.
Chuck
BTW, when there"s air in the system, it cranks really fast and it sounds like it wants to start. It won"t.
Chuck (CA)
02-23-2008 19:46:15
 One More Thing in reply to Chuck (CA), 02-23-2008 19:42:48
You know,
This would be a great time to replace the filters. Thank you John UK for that tip!
