Re: MF 135 Draft control
ltolson
03-09-2008 15:35:51
David
I did just that today. The tube does move when the position control lever moves. I assume then that the problem must be under the lift cover?
Larry
ltolson
03-09-2008 15:38:20
 Re: MF 135 Draft control in reply to ltolson, 03-09-2008 15:35:51
By the way why is it referred to as a quadrant?
DavidP, South Wales
03-10-2008 06:27:39
 Re: MF 135 Draft control in reply to ltolson, 03-09-2008 15:38:20
Hi,
Now that we know the tube is moving there is a strong possibility that there is a problem with the roller linkage under the cover.
DON'T attempt to remove the cover until you have a manual or come back and I'll guide you through it.
As to 'quadrant'? A quadrant is generally anything that is one quarter of a circle so whilst its not exact, its fairly close.
DavidP, South Wales
