Re: 175 Steering
Eric in IL
03-10-2008 10:20:25
The J.B. Weld may or may not work, but I would try it. What have you got to loose ? I like the "kwik dry" formula and use it on alot on bearing races, even if they fit good. Can you remove any material at the slot where the clamping bolt goes ? Maybe,by using a larger angle grinder ? I dunno just a thought.
