Update on 275 lift poblem
awoods
03-10-2008 13:24:22
To recape lift wouldn't stay set would continue to go down or up witchever the last you did to it.
I have now replaced the controll valve been through all the adjustments. when you ajust it following the book it will dump down as soon as you add some preasure to the back of what is hooked up too. It still goes down or up on the last move you make the only diferance now is you can bumb it back just a hair and it will hold, dosn't leek down after that or go down or up any more if running. You can adjust the dumping down out of it. Have seen where some welding was done to the top not sure if some wrong parts were istaled in this top bought tractor don't know the history. It works if you move the valve manualey.Im thinking may need to replace whole roker assemblly becausre don't know how to pinpoit problem.
Anyone have any Idears?
