M135 starting problems
Brian
12-28-2000 13:13:38
When its cold, my M135, with continental gas motor, sometimes just whirls when I hit the starter key. By whirl, I mean it sounds as if the starter is whining, but not turnig the crank wheel. Sometimes it might happen two or three times in a row and then it finally catches and takes right off. Happens only when engine is cold and weather is cold. Am guessing the starter /solenoid needs some cleaning, but was wondering if anyone can shed some thoughts.
Cal S
12-28-2000 16:53:13
 Re: M135 starting problems in reply to Brian, 12-28-2000 13:13:38
Remove starter and clean the gear.regrease with lite grease. if that does not fix problem you could have a weak selinoid. Also check battery for full charge.
