PTO/Clutch problems
Brian Camp
03-26-2008 10:42:55
Having a problem with clutch/pto and hydraulics. Was getting a lot of smoke (smelled like burnt cluth) added hydraulic fluid to point that dipstick showed full however pto only turns when tractor tires are moving (with the gears and not normal PTO speed) and the hydraulics arms on the back won't move up or down. Any ideas? Someone has mentioned clutch problems as the pto and clutch are there together and possibly not getting enough compression to lift the 3pt arms on back and turn the PTO shaft fast enough.
Tramway Guy
03-26-2008 11:40:36
 Re: PTO/Clutch problems in reply to Brian Camp, 03-26-2008 10:42:55
Some of those tractors have a lever that changes the PTO to 'ground speed' mode instead of regular PTO. Sounds like that is what you have and somebody has moved it to the wrong position..
