MF 135 hydraulic cylinder
ltolson
04-05-2008 16:00:59
I removed my lift cover to fix a problem with my position control linkage. I fixed that but I found a crack in the cylinder wall. Is it difficult to replace the cylinder ? I'm concerned about any adjustments after replacement. I assume I should replace the piston and rings as well? I don't want to take that cover off again.
Larry
