Serial Numbers FE 35 and timing mark
Bronzey (Austra
04-13-2008 03:10:26
We are looking for some information about the following serial numbers. We have a petrol engine red/grey tractor. The tractometer shows it is an FE35 model.
The LHS of the tractor near the clutch pedel shows the following stamp MHF 182 840 M2.
The RHS of the tractor near the rear dip stick for the transmission/hydraulics shows MHF 183-253-M5.
Not sure why these two numbers would be different??
Also, can anyone advise us where the timimg marks are located for the petrol engine??
Thanks and cheers.
Masseynut
04-15-2008 04:16:23
 Re: Serial Numbers FE 35 and timing mark in reply to Bronzey (Australia), 04-13-2008 03:10:26
Hi Bronzey, Your tractor was manufactured in 1958, standard petrol only model with a single stage clutch. regards, Evan.
Masseynut(Australia)
04-13-2008 04:29:41
The numbers you have there are casting numbers, if you can give me the serial number off the aluminium tag riveted on the dashpanel, I can give you a year build date. regards Evan.
Bronzey (Australia)
04-13-2008 20:32:47
 Re: Serial Numbers FE 35 and timing mark in reply to Masseynut(Australia), 04-13-2008 04:29:41
Thanks Masseynut
Its SGF 99372.
