MF 165, need some info...
Chris
01-01-2001 14:51:57
I just bought a MF 165 diesel. Bought it for 2500 in an auction. Don't know much about history, not sure about the year, but everything works on it, and it started good considering it was 10 degrees outside. I would like to know some specs on it, hp, torque, what is a good size bush hog for it. If it's around 50hp, would a 10 ft be the way to go. I've got some pretty good size hills, I don't want it driving me! Thanks for you time, Chris, nice site too!!
LANCE
01-02-2001 20:29:18
 Re: MF 165, need some info... in reply to Chris, 01-01-2001 14:51:57
CHRIS THE MF 165 IS A VARY GOOD TRACTOR.WE HAVE A LOT OF THEM IN CALIF. THE EARLY TRACTORS USED A GENERATOR THE LATER ONES USED A ALTERNATOR .I THINK THE CHANGE TOOK PLACE IN AROUND 1969 OR 1970.A 7 FOOT BUSH HOG IS A GOOD MATCH.WE WOULD PAY $4500 UP FOR A TRACTOR LIKE THAT.I THINK IT IS ABOUT 50HP AND 42PTO GOOD LUCK LANCE
LANCE
01-02-2001 20:28:44
Big Jim
01-02-2001 14:34:29
Chris,
I bought a MF 165 Diesel about 3 years ago. It has been a great tractor. Starts good even in very cold weather. The Perkins Diesel is rated at 52 HP. I pull a 5 foot bush hog through tall grass with it. I owned the bush hog before I had the tractor. A 6 or 7 foot cut would be better matched to the tractor. Get a bush hog that is at least as wide as your rear wheels are set.
Bill
01-04-2001 07:25:34
 Re: Re: MF 165, need some info... in reply to Big Jim, 01-02-2001 14:34:29
Great tractor! I have a 1973 row crop diesel 165 with a Westendorf WL-21 loader. Couldn't ask for a better or more reliable tractor. Easy to work on and find parts for.
Specs:
Years mfg'd: 1965-1974 (I think)
PTO HP: Gas-47, Diesel-52.5
Transmission: 6-speed, 6 w/Multipower, or 8-speed
PTO: Live or independent
Category I 3-point hitch
Swinging drawbar
Advise that you obtain:
1) Operators' manual
2) MF service manual
3) MF parts manual
4) I&T service manual (135,150,165)
5) MF cap to wear when you're operating your tractor.
Good Luck.
