Arp half tracks on MF TO35
goldenhawk
04-16-2008 13:57:03
Does anyone have Arp half tracks installed on a MF 35 or similar tractor? I am in the process of installing a set on my tractor and don't believe I have the proper axle brackets. The brackets fit the axle however the the pivot pins for the idler arms are about 5 inches below the bottom of the tractor axle. I think this puts the idler arm at too shallow an angle as it is almost parallel to the ground when the idler wheel is installed. I have some pages of the installation manual, but it is hard to tell from the drawings where the pivot point should be in relation to the bottom of the axle. Any information would be appreciated.
goldenhawk
04-17-2008 13:17:05
 Re: Arp half tracks on MF TO35 in reply to MED41, 04-16-2008 13:57:03
Don_G said: (quoted from post at 15:56:55 04/17/08) There's a post in the Ford N club forum with the installation instructions. It shows the idler alignment detail.
This site won't let me post the link. If you give me your email I'll send it to you.
Don
Thanks Don & Brian - I was able to find a bit more info last nite, and have decided to fabricate new brackets. Will let you know how it works out. Thanks again!
Don_G
04-17-2008 12:56:55
 Re: Arp half tracks on MF TO35 in reply to goldenhawk, 04-16-2008 13:57:03
Don
Don_G
04-17-2008 10:26:49
Here's a link to a picture in the archives of a 35 with tracks.
Don
Brian Allen
04-17-2008 08:21:29
Hi
From memory, I think that the wheel runs at the same level as the rest of the wheels. That said; it was a long time ago that I last saw my cousin's TO35 W/tracks on it.
Good luck
Brian
