Hyd. Leak
Bob Drinning
04-24-2008 18:01:35
About six weeks ago I bought a MF150 /w multipower. It was running but had serious front end issues. All fixed and good to go, I took her on maiden voyage today.
I found a hole under transmission about level with drain plug on very bottom that is leaking.
This is well behind weep hole with cotter pin in it. It looks like it may have been welded and ground smooth, or maybe a casting mark.
Is this thing suppost to be there?
TEXAS TIM
04-27-2008 23:18:53
 Re: Hyd. Leak in reply to Bob Drinning, 04-24-2008 18:01:35
yes all massys have these holes for the leak dtection water drain . texas is very good country
TEXAS TIM
04-24-2008 20:10:52
yes their are two weep holes in the casting . if yours leaks it trans fluid and will require the split and shaft seal to stop it .
Bob Drinning
04-25-2008 20:40:37
 Re: Hyd. Leak in reply to TEXAS TIM, 04-24-2008 20:10:52
Thanks for the reply. After pulling the clutch inspec. plate, it seems the forward hole is for oil from crank seal, and the rear for tranny fluid.
Is this an inherent problem, and do the the non-multipowers have it?
P.S. I to am from the Lonestar state!
