Massey Ferguson 40
445HydesCreek
04-28-2008 04:16:19
I would like to run a log splitter with two-way ram on the 3PL of my MF40 loader/backhoe (backhoe removed). Can I tap into the loader control bank? If so, which ports? Or should I run it off the tractor"s internal hydraulics via an isolator valve on top of the axle casing? Thanks
135 Fan
04-28-2008 08:54:06
 Re: Massey Ferguson 40 in reply to 445HydesCreek, 04-28-2008 04:16:19
The loader pump will be much faster. You'll probably need to talk to a good hydraulic shop on the best way to hook it up. If the lines going to the backhoe are there, you could probably tap into them fairly easily with a control valve. Dave
