MF 65 Brakes
cat988
04-30-2008 15:29:03
I just bought a MF 65 it sat outside uncovered for 9 years,the right rear wheel is locked maybe the brakes? I tried to rock back and forth but only moves 6 inches the left is good.is there an easy way to free up brakes !!!!
DavidP, South Wales
05-01-2008 00:58:13
 Re: MF 65 Brakes in reply to cat988, 04-30-2008 15:29:03
Hello,
In a word 'No'
Look at the position of the operating lever and rod where it goes into the rear axle and compare.
If the seized one is out further that suggests it iss the actuator plates that are stuck. If not it is probably the brake disc/s to the casing. Jack up the wheel and rock it back and forth as violently as you can by hand. It may work. I would not suggest trying to tow it to free it on concrete or tarmac but might be worth a try gently on grass.
DavidP, South Wales
