mf 65 oil filter and question
Jordan F
04-30-2008 15:54:44
hi all,
where can an oil filter for a mf65 be had. it's got the contintal g176 gas motor in it. also where the o ring on the sleeve sits in the block there is some pitting. is this a major concern?
thanks
jordan
Jordan F
05-03-2008 20:31:54
 Re: mf 65 oil filter and question in reply to Bruce Spurgeon, 04-30-2008 15:54:44
Aaron Ford said: (quoted from post at 08:53:50 05/02/08) You can get a filter from any reputable parts store. The Napa number is 1010, I believe. The Fram number is CP3. You can find the Fram at Tractor Supply Co. If it doesn't leak, no problem. If it does, try a very light film of silicone. I like the grey, but I do not think it matters.
Have the counterperson double check the filter numbers.
HTH
Aaron
thanks aaron
jordan
Aaron Ford
05-02-2008 00:53:50
 Re: mf 65 oil filter and question in reply to Jordan F, 04-30-2008 15:54:44
HTH
Aaron
