MF 135;only shifts r and 2nd
Bser
05-03-2008 14:22:36
I bought a mf135 diesel that runs sweat but will shift reverse and 2nd I think;what can I expect to have repaired?
Masseynut(Australia)
05-05-2008 02:50:23
 Re: MF 135;only shifts r and 2nd in reply to Bser, 05-03-2008 14:22:36
What u may find is that, by removing the transmission oil filler plug,(next to main gearlever), and inserting a screwdriver into the shifter rail that is visible thru the aperature, you may be able to move the rail back or forth, so that it returns to the neutral position. If the selector rail on the far side is the one stuck in gear, you will have to be a little more patient in levering it, and returning it to the neutral position. Don't forget to take the load off the drive-train first by depressing the clutch down. regards, Evan.
Retired MF Dealer
05-04-2008 20:10:13
Sounds like it is stuck either in 1st or reverse, if that is the problem it is easily fixed.
Bser
05-04-2008 14:30:13
CORRECTION: the shifter only moves back and forth;will not shift sideways;goes into high and low range..... . this info help diagnoes? THANKS!!!!! !!
05-04-2008 00:26:21
Does the gearstick move into 1ST and 3rd positions, or just lock up? Evan.
