MF135: need trans gear and shaft
Bser
05-20-2008 16:24:29
I have a MF135 that had a problem shifting only into first and reverse. The gear is galled to the shaft and must be forced. The gear is now chipped from being forced. What is a good source of used parts and what are they worth? I'd like to use the tractor soon and would really appreciate any help.
Retired MF Dealer
05-21-2008 14:12:15
 Re: MF135: need trans gear and shaft in reply to Bser, 05-20-2008 16:24:29
You can most likely buy new parts as cheap as the used ones.The gear should be less than $100 for a new one. If you have a six speed trans. you should be able to buy the shaft for less than $200. Be sure and measure the shaft because there are a couple of different lenghts on the MF 135. If you need more info send me an email.
"Retired"
