135 pto problems
stan
01-06-2001 13:59:00
pto stops working under load,pto is independent type,will work sometimes if you shut tractor off and start with pto engaged.lift works fine.
Darrell McDaniel
02-07-2002 08:32:29
 Re: 135 pto problems in reply to stan, 01-06-2001 13:59:00
When tractor is running P T O Won't engage. It just grinds even with clutch in.
Big Dean
01-06-2001 16:09:14
Stan Either your independent PTO pump is weak or the clutch pack is wore out it could be a little of both. If i can be of further help E-mail me
