135 lift question
Jeff
01-13-2001 21:39:05
when the tractor is first started up the lift works fine after it warms up it seams to weaker. Is that the pump going bad,if so what do you have to do to fix, does the tractor have to be split in half to get to the pump? Thanks for your help, Jeff
Shawn Goll
01-15-2001 19:46:39
 Re: 135 lift question in reply to Jeff, 01-13-2001 21:39:05
Have you recently cahnged the trans-hyd fluid...That makes a big differnce.
