Mf 285 banging noice in transmission
Bob Levy
01-14-2001 08:30:48
While plowing snow with a blade the tran. startedto make a banging sound occasionally, I still had all the gears and could drive it . upon further inspection the spring on the shifting lever was broke. I draIN THE HYDRO. FLUID and found some small parts that look like pieces of spring that have been flattened by being crushed by gears. there isn't any more banging noice since draining hydro, oil ,and finding small parts. I'll fix the broken spring , but is it safe to use if it doesn't make any more sounds or symtoms?
