Mf30b-leaking oil and cluth not cutting off pto
allen
01-15-2001 19:27:55
this is my first time getting a mf. and i bought a mf30b industrial with pto and loader--it smokes some and haven't used it enough to know if it bursns oil-a mechanic suggetsed it might have a broken piston(frightening)--also it has the cluth does not shut off the pto when pushed in-does it need adjusted or is it gone..i paid 5k and the tractor looks and runs decent but the oil pressure is in green close to yellow..please somebody give me some info as i am ignorant in tractos and especially mf..my previous experience has been with fords
LANCE
01-15-2001 20:39:47
 Re: mf30b-leaking oil and cluth not cutting off pto in reply to allen, 01-15-2001 19:27:55
MF 30B IS ABOUT THE SAME TRACTOR AS MF 135 AG TRACTOR.I WOULD GET A IT MANUAL FOR MF 135.I THINK YOU PTO CLUTCH IS OUT OF ADJUSTMENT .REMOVE THE INSPECTION PLATE FROM THE BOTTOM OF CLUTCH HOUSING.THERE ARE THREE SCREWS TO ADJUST WITH A 1/2 INCH AND 9/16 WRENCH.USE A FEELER GAUGE TO CHECK CLEARANCE BETWEEN HEAD OF BOLT AND HOUSING.ADJUST TO .070 THE BOOK CALLES FOR .090 BUT .070 WILL WORK BETTER.IF IT IS LEAKING OIL IN TO CLUTCH HOUSING CHANCES ARE IT THE PAN GASKET
Shawn GOll
01-15-2001 19:44:44
I have the exact same problem with my massey 135....I wonder what it could be
