MF 135 Draft Control
Brett Barham
01-18-2001 13:46:24
My MF 135 Draft lever does not work at all. The Position control works fine. I have moved the response lever with no change. Any suggestions?! Also where can you find the I-T manuels that everyone is talking about using? Thanks.
Jerry in Id
01-18-2001 22:45:35
 Re: MF 135 Draft Control in reply to Brett Barham, 01-18-2001 13:46:24
Try intertec.com for your I&T manual. Go to the on line book store and you can order the manual from them.
Bob
01-18-2001 17:44:24
Most likely is that the draft shaft is rusted into the bore. This requires removing the lift cover and cutting the shaft, cleaning the bore and replacing the shaft. You must have a manual for instructions on removing the lift cover or you will do damage!
The manuals are available from some of the advertisers here. Look under "MARKETPLACE".
Bob
