175 mf
cliff
01-18-2001 18:54:34
what is the going price for a 175 with a freeman loader on it with a perkins diesel motor also are they a good dependable tractor do they have any quirks i am looking at a decent looking one so any help would be really apprecated thanks in advance
David
01-19-2001 19:14:46
 Re: 175 mf in reply to cliff, 01-18-2001 18:54:34
It's hard to tell without looking. That unit could go from $4000 to $10000. The front end of a 175 wasn't designed to work with a loader. If you plan on using the loader a lot with heavy loads, you may see some trouble. The 175 in general is a great tractor, I own 2 myself. One thing that really helps is putting wider tires and rims on the front. That will help cushon the weight from the loader. Good luck, David. BTW, keep a close check on the front wheel bearings if using a loader, the entire kit is inexpensive if you need to replace.
