MF 65 Hydraulics shaking badly
Billy Cathey
01-20-2001 09:10:26
The hydraulics on my MF 65 have started shaking badly. When the 3 pt is raised the whole tractor shakes. What could the problem be? Started when the weather turned cold. I started the tractor and let it warm up for about 10 minutes, then started down the road to do some work. The 3 pt suddenly dropped and now when I raise, it shakes BADLY!
Thanks
Billy
Jack in NB
01-22-2001 06:20:24
 Re: MF 65 Hydraulics shaking badly in reply to Billy Cathey, 01-20-2001 09:10:26
Hello Billy -
Sounds like a blown o-ring in one of the pump valves.
You can check by removing the right cover (with the trans oil level stick); with a light and mirror you can see the oil erupting from the top of the pump, when lifting a load, if that's the problem.
You'll have to put the right rear wheel up on a 6 x 6 or 8 x 8 block to tip the oil away fron the opening (or lose a gallon of oil!). Be sure to block the tractor securely from rolling.
If that's the problem, pump needs at least an o-ring kit. Shop manual is strongly recommended to help get things adjusted when re-assembling.
