VR Connections
Bill Stanley
01-24-2001 14:23:45
MF 35 with 12 volt generator and Delco Remey voltage regulator. The voltage regulator has four wires, three on the right side and one underneath.
I have been chasing a charging problem for weeks. Could some one look at their VR and verify the connections.
My VR is connected as follows:
Field - top Battery - center
Lights - bottom
Armature - underneath
Any help would be appreciated.
Bill Stanley
Dan
01-25-2001 16:33:05
 Re: VR Connections in reply to Bill Stanley, 01-24-2001 14:23:45
Hi Bill,Take a look at this site. Maybe it will help.
http://albums.photopoint.com/j/ViewPhoto?u=167324&a=1220311&p=14334656
Bill Stanley
01-25-2001 17:52:49
 Re: Re: VR Connections in reply to Dan, 01-25-2001 16:33:05
Thanks. I found, looked at and printed the wiring diagram several weeks ago. The tractor appears to be wired correctly except the ampmeter is not in use.
I am not sure the VR connections are correct especially the B and L terminals. I have had the generator and regulator off more times than I care to admit. The terminals have always been connected as I found them but I now wonder if they were correct to begin with. F and G are not in question. Everything appears OK but the system is not charging and I am trying to find the detail that has been overlooked.
Which terminal on your 35 does the does the B or battery terminal connect? Is it at the bottom right of the VR or the center right?
Bill Stanley
