MM Serial Nos.
Harold, Ia
11-03-2002 17:02:14
Someone told me that there is a place on the internet where you can register your tractor serial numbers with your name and see where other MM tractors are. They would be in numbered and model sequence. Is there should a thing? and if so how do you get on to it? Thanks for telling me if I'm daydreaming or not. Harold, Ia
Jim Parisot
11-04-2002 10:16:06
 Re: MM Serial Nos. in reply to Harold, Ia, 11-03-2002 17:02:14
Harold, Ia, you are on that site. On the left of your screen just click on Tractor Registry under the heading Research and Info. I strongly suggest you also look at Brian Rukes site, and register your tractor(s) as Jeremy suggested. Hope this helps.
Jim
Jeremy
11-03-2002 21:01:31
I'd guess you are hearing about the MM Registry I'll leave a link at the bottom.
