MM UTS
8n?9n?
11-06-2002 12:55:10
Found a MM UTS the engine is stuck but the tractor is complete has one bad rear tire but all sheet metal is there and is in good shape. Any idea what a good price would be it is a 51 model LP tractor with the 283B-4 engine.
deadeye
11-06-2002 14:49:02
 Re: MM UTS in reply to 8n?9n?, 11-06-2002 12:55:10
Are all of the engine parts there? LP carb, power steering pump, hyd. cylinder, etc. if it has one?? Frt. tires any good?? Depends on the part of the country you are in as to how much it is worth and how bad you want it. I would guess $300 to $600 at the most if you could turn it over by turning the fan. Look to see if the hood is burnt thru on the right side if you were sitting on it. Also check the exhaust manifold for rust thru. Poke it with a screw driver as it is probably bad if it has sat around with no can or cover. Check the serial number plate on the right side about where the belt pulley would be and see what you really have. It probably has 102710 heads on it and you can part it out if nothing else and make some bucks on it. Don't know if this will help you or not. Where is it located?? East, Midwest, South, West????
8N?9N?
11-06-2002 15:39:21
 Re: Re: MM UTS in reply to deadeye, 11-06-2002 14:49:02
Hood and grill are both good as is the rest of the sheet metal. The only thing i could see missing was a line to the lp carb and the hole was sealed on the carb. Tractor is in Central Ok. Dont know if i can buy it yet but am trying to contact the people who own it. Both front tires would have to be replace and one back tire the other is weather checked but up.
deadeye
11-07-2002 04:15:29
 Re: Re: Re: MM UTS in reply to 8N?9N?, 11-06-2002 15:39:21
Then if the party will SELL, you can ask what price they might have to have and draw your conclusion from there. Who knows !!! They may give it to you just to get rid of it. Ha Ha
