Head on mm r
peter
11-07-2002 18:49:51
is a 1947 mmrtu head considered a late model head that could go on a 53 zb for higher compression or does it have to be newer??
John G
11-08-2002 06:22:48
 Re: head on mm r in reply to peter , 11-07-2002 18:49:51
The heads on the R & ZB engines are the same for gasoline, RE226C casting #. If you need more compression, you have to find an LP head with a 10A2647 or 10A2648 casting #.
