MM UTU's
Trever Maas-MN
11-09-2002 19:30:23
Whats your opinion on them? I have two of them, ones a 45 and ones a 47. Should I part them out and use the money for some other tractor or take the two and try to make a complete one? I already have a 49 UTS.
Thanks,
Trever
Andy
11-11-2002 21:25:37
 Re: MM UTU's in reply to Trever Maas-MN, 11-09-2002 19:30:23
It depends on how complete they are, what kind of shape everything is,(sheet metal, rims, tires, engine) Don't ruin a good tractor to make a buck or two now, you may regret it later.
Trever Maas-MN
11-12-2002 05:43:53
 Re: Re: MM UTU's in reply to Andy, 11-11-2002 21:25:37
The sheetmetal is all bad on both of them, besides the gas tanks. The tires are bad on both of them. They both don't have front wheels, or carburetors. One tractor has a radiator, if it's good or not. One tractor has a lot of mods to it, including a homemade raised platform, a raised steering wheel kind of like a ZAU. One has a mechanical lift. Both tractors have good heads. But they aren't complete. I can't make one of them from the two.
Andy
11-14-2002 10:01:37
 Re: Re: Re: MM UTU's in reply to Trever Maas-MN, 11-12-2002 05:43:53
Sounds like parts
Trever Maas-MN
11-14-2002 11:20:00
 Re: Re: Re: Re: MM UTU's in reply to Andy, 11-14-2002 10:01:37
Exactly
