G 705 w/ 800 cid
D. Aron Cochran
11-10-2002 16:59:13
I was pondering the idea of seeing how an 800 cubic inch motor would fit in a 1964 G-
705. I was curious if anyone has done it before or heard how it turned out. The tractor will be set up as a puller and I would like to try an 800 motor in there. I would not have usually thought of such a project but the original 504 motor it had threw a rod... Any feedback is appriciated.
Dave N
11-11-2002 15:31:24
 Re: G 705 w/ 800 cid in reply to D. Aron Cochran, 11-10-2002 16:59:13
It will bolt right up use the 705 flywheel. May have to do something with top rad. hose the 800 is taller. have to covvert the governor to varibale speed from constant speed. I think the governor control is on the other side also.
farmerjosh
11-11-2002 07:32:06
I havent done it bit I have seen a few before...they worked out great and one was even used for field work...as long as you didnt tie it to the ground I think the tranny and rear end would hold up nicely
