MM 585
John
11-26-2002 16:35:05
How many hours can be expected out of a 585, without the updates like the external oil pump, before a rebuild is needed? Anything else I should be looking for? Thanks.
Jeremy
11-30-2002 19:10:42
 Re: MM 585 in reply to John, 11-26-2002 16:35:05
Our's had 2300 when the gear on the end of the oil pump went out! Cam gear was fine.
John
12-01-2002 09:15:39
 Re: Re: MM 585 in reply to Jeremy, 11-30-2002 19:10:42
Jeremy
Did you just put a new gear on the end of the oil pump or did you switch it over to an external pump. I was looking for a way to make this engine reliable. This A4T has 2100 hours on it, and no external pump. What did the 2-150 Whites use for oil pumps?
m kuhns
12-01-2002 18:30:13
 Re: Re: Re: MM 585 in reply to John, 12-01-2002 09:15:39
The 2-150 White uses a gear pump right below the injection pump. The problem is that I think?? your hydraulic pump is mounted where the external oil pump is mounted. Our 2155 oliver had the hyd. pump mounted on the engine so we couldn't convert it over without losing the hydraulics or doing some other modifications.
howard
12-05-2002 08:28:57
 Re: Re: Re: Re: MM 585 in reply to m kuhns, 12-01-2002 18:30:13
Not all 2-150's had external oil pumps.
I have one with a internal pump.
M kuhns
11-28-2002 15:58:15
The engine will live fine as far as pistons and rings and rod bearings. Life of the engine could be extended by dropping the pan and changing the 4 main bearings which will wear out before anything else except for the cam gear. The cam gear where the internal oil pump drives off of will wear out before the engine itself will. The engine is solid at 150 hp except for the camshaft and oil pump gears wearing out.
John
11-29-2002 14:03:18
 Re: Re: MM 585 in reply to M kuhns, 11-28-2002 15:58:15
How many hours does it take to wear out the camshaft and oil pump gears?
larry h
11-26-2002 16:54:37
3000 hours would be the avg. i have seen
