Help with 3pth
Charlie
11-26-2002 16:45:20
When I connect my top link to my Jet Star 3 it won't
raise the rear of the bush hog up because where I connect it is not a ridgid mount. Any ideas.
Kelvin
11-26-2002 17:33:48
 Re: help with 3pth in reply to Charlie, 11-26-2002 16:45:20
If you're hooking to the correct place, there should be a bolt on each side of that casting with a spring on both sides of the mount. It has a shaft at the top that it pivots on. One of the bolts is supposed to have a big funny welded on head, so you can remove it with a crescent wrench to put the pin in the lower hole.
