Carb freeze up and spark plugs cold after 1/2 hour of use
peter
12-01-2002 17:52:20
are they related problems ????
Roger
12-07-2002 18:01:28
 Re: carb freeze up and spark plugs cold after 1/2 hour of use in reply to peter, 12-01-2002 17:52:20
Is this a gasoline tractor? Could be you have an
intake off an LP Gas motor. The gasoline will not
vaporize and ignite correctly. It was common for
farmers to put LP manifolds on Gas motors. It gave
them more power, however they did not run
correctly in cold weather.
