800 hd
dick
12-01-2002 20:16:50
help have 800 hd mm need flywheel. have several gbd 425 505 they all have 6 7/8 flange 800 has 5 3/8 flange also has one piece rear seal flange if that makes a diff appr the help
dick
12-03-2002 22:14:56
 Re: 800 hd in reply to dick, 12-01-2002 20:16:50
the flywheel im looking for is for late model 800 hd looking at rear of engine with flywheel removed rear seal flange is two piece an end of crank shaft measures 6 7/8 across on old sryle 800 new style again with flywheel removed lookin at end of crank is a one piece flange with lip seal and end of srank measures 5 3/8 across these new style were not installed in any tractors only stationryengines that i know of any help in locating will be greatly apper
Jason
12-09-2002 08:36:02
 Re: Re: 800 hd in reply to dick, 12-03-2002 22:14:56
This requires some machining to be done. On the Twin City forumn you can find out how.
Howard H.
12-03-2002 14:46:12
Hi Dick,
Do you mean you are looking for a HD 800 engine flywheel??
Is it in a tractor or are you talking about an irrigation engine?
Where are you located?
We've got one out in the barn for the stationary engines...
CU,
Howard H.
Stratford, TX
fatboy
01-19-2003 13:05:05
 Re: Re: 800 hd in reply to Howard H., 12-03-2002 14:46:12
Hey SC> flywheel man lost your ph# and E mail add wont go call me 307 262 4734 Thanks Dick
