MM Power Unit
Trever Maas-MN
12-07-2002 19:15:22
What do you all need to make a power unit or what can you find power units in? I was considering making one out of my 21-32 FTA engine.
Thanks,
Trever
Kelvin
12-10-2002 16:31:06
 Re: MM Power Unit in reply to Trever Maas-MN, 12-07-2002 19:15:22
Trever, isn't the 21-32 engine made without a bell housing? Or am I confusing it with some other MM/TC model?
Trever Maas-MN
12-11-2002 05:45:01
 Re: Re: MM Power Unit in reply to Kelvin, 12-10-2002 16:31:06
Your right.
John G
12-08-2002 09:16:32
At the very least, you will need the front stand, radiator with mounts, and the rear bellhousing which incorporates the stands. I'm only familiar with the 265 p/u, but I had to use a power unit flywheel to have the correct timming marks. I may have a book on that & could copy a page or 2 if you need. John
Trever Maas-MN
12-08-2002 16:02:33
 Re: Re: MM Power Unit in reply to John G, 12-08-2002 09:16:32
That would be great.
Thanks
dick
12-08-2002 19:29:55
 Re: Re: Re: MM Power Unit in reply to Trever Maas-MN, 12-08-2002 16:02:33
I have all the parts you need to make a power unit stationery type
Trever Maas-MN
12-09-2002 05:38:22
 Re: Re: Re: Re: MM Power Unit in reply to dick, 12-08-2002 19:29:55
What do you have?
Thanks
