MM U Reproduction Hood Side Panels
Pete Brandel
12-09-2002 21:15:32
Finally I have found someone that reproduces both side panels for MM U hoods.They are reproduced exactly like original panels with louvers,all the correct bends,and new latches riveted on.The panels have the exact spot welds also.I was a vendor at the Pioneer Power Swap Meet at LeSeuer Minnesota this spring.I was selling MM parts and a gentleman approached me about borrowing a MM U hood for a pattern to reproduce the side panels and hood.He picked up the hood this fall and today returned the hood with a new reproduced side panel.It is a perfect reproduction.His name and address is Arnie Lillo,56632-177th Lane,Good Thunder,Minnesota.56037.Phone number is 507-278-4302.Email is alillo@hickorytech.net
Jason
12-14-2002 19:49:34
 Re: MM U Reproduction Hood Side Panels in reply to Pete Brandel, 12-09-2002 21:15:32
I need a pair of hood side panels for a UB Special. Anybody make those? Jason
Jack Blaylock
12-10-2002 06:30:51
Good job Pete. Glad to hear that someone has finally filled the gap on the hood problems. The other problem of the manifold replacements has sure improved the restoration of many tractors also. Just goes to show that progress is being made on this old/NEW equipment,---Thanks.. Probably see you at Albert Lea.---deadeye
kevin moschenrose
12-09-2002 22:53:23
HEY,HEY, Two thumbs up to you on this. That is really great.
