Early Z
David B
12-11-2002 20:22:11
Could an early Z tractor have an open radiator with "twin-MM-city" stamped in the tin top tank, doesn't have a cast iron top tank. Could it be a J radiator on a Z?
John G
12-11-2002 21:01:43
 Re: early Z in reply to David B, 12-11-2002 20:22:11
The early Z & J/RE motor shared everything except the fuel tank,hood, radiator, and front pedestal. I have a '37 JTU and a '39 ZTU, the z has the traditional Z frontend and the J has the same frontend, radiator,and fuel tank as the J/Waukesha. My J has a right front air cleaner and my Z has a left front mounted air cleaner, the J and some EARLY Zs had a front mounted aircleaner. I have seen one of the Zs with the front mounted aircleaner, seems like it had a J frontend, have to see if I can find that picture.
Mark
12-13-2002 17:58:27
 Re: Re: early Z in reply to John G, 12-11-2002 21:01:43
MM used RE Z engines as replacements in the JT's. The early ZTU's looked like JT's with the front mounted air cleaners, but I dont think the radiators had Twin MM City on them. What does the serial no. tag say it is.
