Early/late Model R
Ethan Berry
12-18-2002 11:58:47
I was curious if any good MM folks new how much different the hoods were between the 1939-40 model Rs and the later years with the regular gas tank. Was the 39' narrower in the back or not? What about other mechanical differences between 39' models and 40s-50s machines?
Ryan
12-23-2002 05:55:24
 Re: early/late Model R in reply to Ethan Berry, 12-18-2002 11:58:47
The rearends on the later R's were a bit stronger I am told. I think someone told me once that the later ones had 4 bolts on the pinion where the earlier ones had 2.
Ryan
Tyler
12-18-2002 17:58:22
Im not sure if the earlier hoods are narrower or not but I do know that the later model hoods have slits at the rear of the hood to make room for the 2 piece tank flange. also the 49 and later hoods abandoned the side curtains all together and are of one piece contstruction.
kelvin
12-19-2002 16:56:04
 Re: Re: early/late Model R in reply to Tyler, 12-18-2002 17:58:22
Yes, the '39 and early '40 hoods are narrower than hoods on later R's.
Ethan Berry
12-20-2002 06:23:21
 Re: Re: Re: early/late Model R in reply to kelvin, 12-19-2002 16:56:04
Is the front width of the hood the same? Did all R's have the same grill and radiator width? Just considering if my radiator and grill off a 47' will work on a 39'. Thanks!
Jim Parisot
12-20-2002 07:46:50
 Re: Re: Re: Re: early/late Model R in reply to Ethan Berry, 12-20-2002 06:23:21
Ethan, you will be fine with the '47 radiator shell and grill on your '39; radiator itself should be good to go, too. Any radiator shell and grill off a Z will work, too. In other words, they are the same. Hope this helps.
Jim
